ORIGINAL: calvinlo
Mine is the Booster Prop 4Ch. So pushing the stick lower left should work right? By chance do you think the problem has to do with the setup on my transmitter, which is as follows:
Mode 1
Elevator up/down - Booster Accelation
Rudder - Booster Steering
Aileron - Turret left/right
Throttle - Gun elevation
proportional RC-set cable set which allows the connection to a common RC receiver with at least 4 channels.
The channel layout is as follows:
Channel 1: Booster acceleration
Channel 2: Booster steering
Channel 3: turret rotation
Channel 4: half deflection - main gun elevation (up/down), full deflection - main gun shot and MG shot.
Other functions (engine ignition, light control) are mapped to diagonals of channels 3 and 4.
When the sound module ThinkTank Blaster is installed, two further channels can be optionally connected for user defined samples.
Minimum number of channels: 4
Hope that helps I will be offline for a while...
The Blitz
