RCU Forums - View Single Post - HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 03-01-2008 | 01:03 PM
Campy's Avatar
Campy
Default RE: HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I have a rack attached to the wall. I made mine with the 12" metal arms and track that the arms slot into. The arms are covered in pipe insulation to protect the plane. You can set up 2 separate racks (one for fuselages and one for wings ) or just put the fuselage under/over the wing on the rack.
This is a quick and easy install and relatively inexpensive. Everything you need is available at an Ace or True Value hardware store. Lowes and Home depot should also have the stuff.
