RCU Forums - View Single Post - Ignition module placement
Old 03-01-2008 | 10:58 PM
CB36
Default Ignition module placement
Hi all;
Is there any reason why I shouldn't put the ign module for my Fuji 32EI on the front side of the firewall, near the engine? It sure would make running the plug wire easy. If not, can I simply encase it in foam and stuff it behind the firewall with it's battery?
If I can, should I screw it directly to the wood or isolate from vibration?
Do I need to wrap it in aluminum foil to supress RFI?
Thanks everybody!!
CB36
