RCU Forums - View Single Post - MT2 18ss fuel issue
Old 03-03-2008 | 05:33 PM
conservative
Default MT2 18ss fuel issue
Greetings all,
I completed some of the break in runs on this truck. It ran pretty good, i'll have to adjust the throttle to be open a bit more at idle. I noticed that fuel was in the pressure tube that runs from the tank to the exhaust. Is this normal? From what i understood this tube was for pressurizing the tank only. why would there be fuel in it? I also noticed that fuel was coming out of the exhaust tip. Not spraying out but it was coming out in drops so the concrete was wet where i was running it for 2 tanks. I haven't messed with the rich/lean adjustments at all. Is this normal during break in?
thanks
