RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
MT2 18ss fuel issue
Old 03-03-2008 | 05:33 PM
Default MT2 18ss fuel issue
Greetings all,
I completed some of the break in runs on this truck. It ran pretty good, i'll have to adjust the throttle to be open a bit more at idle. I noticed that fuel was in the pressure tube that runs from the tank to the exhaust. Is this normal? From what i understood this tube was for pressurizing the tank only. why would there be fuel in it? I also noticed that fuel was coming out of the exhaust tip. Not spraying out but it was coming out in drops so the concrete was wet where i was running it for 2 tanks. I haven't messed with the rich/lean adjustments at all. Is this normal during break in?
thanks
Old 03-03-2008 | 07:46 PM
Default RE: MT2 18ss fuel issue
ya in the break in part you run out of fuel fast bcuz is so rich when you lean it out it will stop doing that but dont make it to lean
Old 03-04-2008 | 06:31 PM
the manual says that during idle the carb should be set to about 1 mm but mine will not idle at that setting. It dies. I have set mine to about 1/4 of the way open. is this normal? what could be wrong? Also, the manual says that you shouldn't adjust the lean/rich setting. Does the engine lean out as it breaks in? I don't wanna screw with the unless i have to.
thanks
