RE: MT2 18ss fuel issue
the manual says that during idle the carb should be set to about 1 mm but mine will not idle at that setting. It dies. I have set mine to about 1/4 of the way open. is this normal? what could be wrong? Also, the manual says that you shouldn't adjust the lean/rich setting. Does the engine lean out as it breaks in? I don't wanna screw with the unless i have to.
thanks
