RCU Forums - View Single Post - CA Models Pass-Port Build
Old 03-04-2008 | 11:05 PM
toddblose's Avatar
toddblose
My Feedback: (10)
Default RE: CA Models Pass-Port Build
Today I made and mounted the Hacker firewall. The first thing I do is trace out some blue foam cut it out and use it as the template. You will need to cut a little at a time so you don't get it to small. after you get the template where you need it, trace it out on to what you will be using for the firewall. (I used the 1/8in carbon sandwich panel from CST.) when I get the carbon where I want I will tack it in place with some CA to hold it in place. I then take the motor and get it set then mount it. after all adjustments are made I will glue the firewall in using BVM aeropoxy.
ID:	895197   Click image for larger version
ID:	895198   Click image for larger version
ID:	895199   Click image for larger version
ID:	895200   Click image for larger version
