CA Models Pass-Port Build
#101
In my opinion and experience, Radio South Pro Hinges are the gold standard for 2-meter flying surfaces. I typically use them on ailerons and elevators. They can also be used on rudder although I prefer to use Dubro standard hinges. By replacing the stock wire pin with the appropriate size piano wire which runs the full length of the rudder makes the rudder removal.
Pro Hinges
Dubro
Pro Hinges
Dubro
do you have any advice on how I can install my landing gear?
Mine are not pre drilled, either on the landing gear legs and neither on the plywood mount.
thank you for any advice
