RCU Forums - View Single Post - CA Models Pass-Port Build
Old 03-04-2008 | 11:16 PM
toddblose's Avatar
toddblose
My Feedback: (10)
Default RE: CA Models Pass-Port Build
Next I mounted the landing gear and wheel paints. I will start with gluing in the support plates in the wheel paints, this will help keep the wheel paint in place and I also use a small screw to mount the wheelpaint. I then take and drill the holes in the paints where the axel go through. Before putting the wheel on I will set the plane at 0 deg's and put the paints on and drill them for the mounting screw. After that is done I then put the wheel on and put the screw in that holds the paint on. The reason for not putting the wheel on is the paint will set on the wheel opening that is level.
ID:	895213   Click image for larger version
ID:	895214   Click image for larger version
ID:	895215   Click image for larger version
