RCU Forums - View Single Post - ZN Synergy with T-Canalizer
Old 03-05-2008 | 09:19 AM
Nickolas's Avatar
Nickolas
Default RE: ZN Synergy with T-Canalizer
Hi there,
Thanks for the answer. Have you coated the T-Can with Solarfilm covering in carbon scheme?
After building, sanding anc covering the T-Can, I plan to glue it with epoxy and cotton to the upper surface of the curved fiberglass base. I plan to sand the base before that. I don't think I will use M3 screws. Then the base will be installed behind the deck with clear tape. Do you think that will be ok?
Also here are some pics of my Synergy, powered by a YS 160 DZ. It flies well but don't have many flights . The rudder is a bit enlarged, also have the original one and will give it a try after installing the T-Can.
Regards,
Nikos
ID:	895407   Click image for larger version
