RE: Flying Foward
a couple of things...check for a level swashplate...then once that is level, you should be ok or close to ok... if you are only close to ok, then check the balance of the heli. the battery tray offers a little bit of forward/backward weight distribution. its most likely your swashplate.
quattro
