RCU Forums - View Single Post - *CA Applicator Tips*
Old 03-05-2008 | 08:52 PM
somegeek's Avatar
somegeek
Default RE: *CA Applicator Tips*
ORIGINAL: BillyGoat
Read a tip somewhere about using a thin piece of wire to direct the flow of thin CA. Put the end of the wire where you want the glue applied and drip CA on the wire and let it run down the to the desired spot.
I do this with toothpicks or pins for CA hinges with good results.
somegeek
