RE: charging fieldbox battery issue
Normally a 12v charger when connected and charging is up around 14 volts and the battery after a charge should be around 12.5volts or better. Do you have a volt meter you can connect directly to the battery terminals? That would tell you if the battery is good/bad. If good, then your power panel is somehow messed up.
