RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 03-06-2008 | 11:50 AM
  #1418
frieshoo's Avatar
frieshoo
My Feedback: (20)
Default RE: DL-50 engine
Yoga,
Not sure about the plug threads. Are you using the washer that comes with the plug? You might try a NGK CM6... I didn't use the plug that comes with the DL.
The coil spring goes in the spark plug cap. I'm guessing it's a spare. Your spark plug cap should have the spring installed.
The pitts muffler will cut the rpms down some.. but these engines are very strong... I doubt you will notice the slight drop.
