RCU Forums - View Single Post - CA Models Pass-Port Build
Old 03-06-2008 | 01:41 PM
  #45
toddblose's Avatar
toddblose
My Feedback: (10)
Default RE: CA Models Pass-Port Build
Here are the weights on my pass-port.
Pass-Port
Fuse with canopy and chin cowl 1190 grams
stab 92 grams ea.
wing 396 grams ea.
rudder 56 grams
set of wheel paints 35 grams
total weight less gear and tubes 2257 grams
I check the weight on everything else and the total weight is 2526 grams.
The weight on my Pass-Port is 10lbs 14oz with FlightPower Evo 5350 5sp X 2. Just remember I am running the Hyde mount and tail ring, one extra servo and a 48in lead for the rudder. So I believe that running the standard rudder and the motor hard mounted will not be a problem.
Here is mine almost done.
ID:	896224   Click image for larger version
ID:	896225   Click image for larger version
ID:	896226   Click image for larger version
