RE: Flying Foward
I have my swashplate slightly tilted forward for a more level attitude in hovering. It also helps when you're flying around...less input on the forward cyclic and easier to keep in motion. Just like quattro mentioned check the swashplate and you can also check the servo arms to make sure they're perpendicular to the ground when you arm the heli. Good luck and hope things work out.
