RE: elevator epoxy question
I have been using nothing but CA since the ARF craze started - never had a problem. Here is what I do -
Fit the elevator, remove the required covering then put it back in. Line it up and then run some thin CA in the joint and follow it up with some medium. The thin will suck the medium right into the joint. I have been doing this on everything - even Giant scale. I defy anyone to break the joint.
