ORIGINAL: quist
Is it going to be hard to balance with 4 servos in the tail? The Ultracote on the rudder inside looks better.
Tony
The first one was rigged almost exactly the same and balance was not a problem. Remember they are mini servos back there at something like 18 grams each, no where near the weight of a standard servo. I think the batteries will end up about an inch from the firewall when using 5300's and up against it with the lighter 4200's. I let you know for sure once I get it flown.
Chip
