RCU Forums - View Single Post - Hovercraft ramp
Old 03-08-2008 | 12:27 PM
cyclops2's Avatar
cyclops2
Default RE: Hovercraft ramp
You can use a servo with the potentiometer disconnected & left centered. Then use it as a variable speed motor .
I have modified a channel in a transmitter by puttin a 5K ohm resistor in each lead of the channels potentiometer to furthur reduce the low speeds of the servo motor. You can also put resistors in the leads of the servo motor to slow it down.
Think about it. The lights will come on for you.
