Here is a more powerful cg calculator that also figures in your stab size. You can also vary your static margin to give you a range on your cg. Static margin also can help you set up you plane for the type of flying you do - 3D, pattern, etc..
http://adamone.rchomepage.com/cg_calc.htm
Tim
