Need CG help on my tiporare
TX
ORIGINAL: flatspin58
i'm guessing on the CG,Looks like about 5 !/4 from the leading edge. I'm i close?
I've got a WK Tipo and the instructions say to put the CG 3/8" - 1/2" forward of the centerline of the main gear.
Tim
TX
If you built it as a tricycle gear, the numbers I gave you should work. If not, or if you want to be sure, here's a link to a CG calculator. Just measure, plug in your numbers, and it'll spit out a CG range for ya. Good luck and let us know when she flies!!!
Link: http://www.geistware.com/rcmodeling/cg_calc.htm
Tim
Tim
CA
Thanks for your help Tim and Dave,I was pretty close with my guess it calculated to 5.23 with the link Tim gave me.That at about 33 %.Have Mach 1 to start on next and the CG on the plans looks way off to me,That link should be a great help.
TX
Here is a more powerful cg calculator that also figures in your stab size. You can also vary your static margin to give you a range on your cg. Static margin also can help you set up you plane for the type of flying you do - 3D, pattern, etc..
http://adamone.rchomepage.com/cg_calc.htm
Tim
Tim
CA
Thanks again Tim for your help,Should have it ready next weekend.Hope it don't fly like a brick, Its coming out pretty heavy.Hope i can keep around 8 1/2 pounds.
TX
Glad to help! Good luck with your maiden. I've got a MK Curare about 1/2 built, a WK Tipo NIB, and just received a Super Curare that has the stabs mounted, but nothing else done. I need to get off my butt and get to building. I wasted my winter getting a couple of pylon racers and my Aurora going. I'm thinking about putting the Curare on the shelf and getting the Tipo built first. It's a 'glass fuse, so I could possibly get it done faster.... decisions!!
tim
tim
