RCU Forums - View Single Post - O.S. 46 will not start.
Old 03-09-2008 | 10:33 PM
bruce88123
Default RE: O.S. 46 will not start.
ORIGINAL: yetti831
I removed the plug and applied the glow starter. The plug momentarily became red hot and then died out. Am I correct in thinking that if the plug was faulty it would not light at all? If this is the case, then my glow starter is not holding a charge.
Not necessarily. It could be the plug had continuity (was good) until the wire heated and then the circuit opened. Pick up a couple of OS #8 plugs for spares and then test with one of those.
