RE: Mini Titan thread
Thanks Oster and Crossfade.
I don't see the Sonix parts that you mention but I think I'll just get the TT PV0805. They are only $21.99 at heliproz so I'll most likely order them there. The complete CNC shaft looks awesome but I can't really spend that kind of money right now. It looks like they sell the same one at helidirect.com If I have another major head malfunction then maybe I'll do the aluminum head. If any of you do get that aluminum head set, please let me/us know how well it fit without modifications and how well it performs.
I guess it would be cheaper in the long run to just get the CNC shaft all in one set instead of piece by piece. If I break anything else on the head then I might just get the CNC head. Other than that and a motor heatsink, I'm hoping to keep this MT stock.
Thanks for the CA on the bearing block screws tip Oster. I didn't know if that would be a good idea to do. It's funny because when they are loose, they don't want to come out any further but just enough to allow the bearing block to shift a little in the frame if I push or pull the plastic head.
I assume you guys feel the rest of the MT is good enough to keep stock?
Dave D.
