RE: Four-Cycling a Two-Cycle Engine
Thanks for the advice, guys.
Must I do that process (richen the high speed needle) at full throttle (WOT) while listening for the "Harley Rumble" or can I do it at mid-throttle (or less)?
I will try it with the Magnum 46, just hope I don't screw up a nicely running engine. I should probably run down to a local Harley shop and listen to some of those engines!!
Frank
