Thanks Oster.
After my last incident I just thought about if and when I'd replace the whole head. I thought I'd stick with the Thunder Tiger and get their aluminum mixing arms. This way if/when I upgrade more (or the rest of) the head, everything will fit without modification.
My only thought now is that in the future, it might be better to upgrade to T-Rex parts since they are more easily acquired. The thing is I'm so new to this and I don't wan't to end up with T-Rex aftermarket parts that don't fit and may or may not be modified to fit the mini-Titan.
In your post you said you're running an aluminum head and tail. I'm curious, what brands are you using and why you chose them?
Also, if I were to buy the complete Thunder Tiger aluminum head and tail, where would the best/cheapest USA based place be?
Thanks!
Dave D.
ps, I'll remember... A VERY SMALL amount of CA on the bearing block screws.
