RCU Forums - View Single Post - Mini Titan thread
Old 03-12-2008 | 01:59 AM
  #280
RC David
Default RE: Mini Titan thread
Thanks Oster.
I've heard a lot about the Kasama head. The thing is, it supposedly wont work with the stock TT woodies and that's what I'm planning to run until I stop breaking things. I tried some Align white and red "Pro" blades but they caused the heli to vibrate a bit. I have a black set to try but haven't yet.
Apparently the Kasama head requires CF blades and I'm not ready to fork out $30.00+ for blades yet since I'll need them often. Then again, my instructor/guru thinks they are a good idea as they do not break as easily from small tip-overs. I'd have to really drive it into the ground and then more than just the blades will be destroyed. Only problem is if I have the Kasama head, I can't even USE TT woodies.
As far as the head, I'm thinking the best/easiest route might be to buy the Thunder Tiger metal head that the SE uses. I don't think it's head is available seperately yet but hopefully when I need it, it will be. I really want upgrade parts that fit/function properly from the beginning. I hate the idea of having to cut/file/bend to make something fit correctly. Too many years doing custom RC models I guess.
In reference to the Sonix parts, can you give me exact part numbers as I'm still having trouble finding them on Helidirect.
Also, why can't I find the Helidirect "deal of the day" stuff? I've looked many times around their website and can't seem to find it.
Thanks!
Dave D.
