Model Tech Extra 300 Arf
BGI, you want to do everything in your power to keep this plane at or under 4lbs maximum. If you can do that, then it really shouldnt matter what motor you put in the plane. Be prepared though to either add lead to the tail, or slice into the foam turtledeck to move your battery allllll the way to the back of the fuse.
