RCU Forums - View Single Post - Cooling head?????
Old 03-12-2008 | 02:33 PM
jetpack's Avatar
jetpack
Default RE: Cooling head?????
ORIGINAL: lildude2599
Just looking for where the water runs through it. If anyone has one can they send me some pics of it so i can see how it is made?
This is a Webra head and jacket. It is more fancy than most but contains O-Ring seals where others do not. You would most likely have to make the head button instead of reworking the original head.
The other kind is more simple to make and probably could shave the original fins off the top of the head to make it flat across, saving as much as the glow plug threads as you can.
ID:	901729   Click image for larger version
ID:	901730   Click image for larger version
ID:	901731   Click image for larger version
ID:	901732   Click image for larger version
ID:	901733   Click image for larger version
ID:	901734   Click image for larger version
ID:	901735   Click image for larger version
ID:	901737   Click image for larger version
