ORIGINAL: planebuilder66
I can't wait to put mine together, right now it's sitting in the box awaitting componets. I have most of the aluminum head parts and a few spare upper crash kits but I will need to change it over to eccpm or try it as is. Can't choose which way to go on that. What motors are you guys running, I was going to run the align bl430 I had but I realized that I wore it out, the bearings are failing in it, causing a high pitch squeal from the stator rubbing on the housing.
There are several motor choices but anything that works in the T-Rex will work on the MX400. I did the CCPM upgrade and even if I buy another MX-400....it too will get the upgrade. The reason on the 120deg CCPM upgrade...a lot less moving parts since it's direct servo to swash, and it allowed me to fabricate an aluminum battery box and I mounted it slanted which fits right in the canopy without a hassle. I am truly impressed with the MX-400 AFTER I did all the parts changes and mods...it's a stout heli.
