RE: Honeybee King v2 tuner shop
If you plugged in the gain wire(the yellow one with one wire) then your gain is set buy the radio, And the stock radio has to low a gain setting to really be usefull. Leave the gain wire unplugged and you can set your gain with the pot on the gryo. remember over 50% is hh under is rate. Hope that helps.
