RE: yet another tiger build
FV432 outstanding work we must shop in the same chains the angle i bet its from B&Q and i have 2 boxes of those springs from maplin love that spring idea on the suspension ive seen a spring adjuster for tensioner on panzerkitten forum and those bearings at the front are they 16mmx8mmx5mm if so got some coming tomorrow collecting all the stuff for mine is taking a bit longer than i thought still should be able to make some sort of start this weekend ive got all the bearings for gearbox except the one above which i need first because everything comes from drive shaft backwards going to make the gearbox with an extra 3.5:1 with speed 400 7.2v motors that should give me tons of torque and about scale speed if ive got it right im in two mind wether to make my own suspension arms or buy a set if the boss gives me some more spending money keep up the good work and keep this post up there bump it when you have done a bit more . all you other guys when the boss takes you to the d.i.y. store do what i do fill the trolly with stuff to do your tanks and when she says whats that stuff for tell her its for this or that the jobs she wants doing.
best regards pete
