RCU Forums - View Single Post - Best pushrod connectors?
Old 03-14-2008 | 12:38 AM
sscherin's Avatar
sscherin
Default RE: Best pushrod connectors?
I'm only using screw locks on the throttle and nose wheel..
All others are soldered clevis on the servo end with a piece of fuel tubing on the clevis to lock it shut.
Horn end is either a screw on clevis with the same fuel tubing lock or a ball link with a double horn (double sheer setup)
This setup does not introduce any twisting loads on the servo arm or control horns.
