RCU Forums - View Single Post - Do I need a Watt Meter? Advice? Thoughts?
Old 03-14-2008 | 08:25 AM
Fast Guy's Avatar
Fast Guy
Default RE: Do I need a Watt Meter? Advice? Thoughts?
Have a look at the Eagle Tree 3 Micro logger. It can record an entire flight for volts, amps, watts, temp, rpm, air speed, battery use in mah, and elevation at 10 samples per second and play it back in real time on the included cool software an you computer.
