RCU Forums - View Single Post - single, double, triple winds?
Old 03-14-2008 | 08:48 PM
proptop's Avatar
proptop
My Feedback: (8)
Default RE: single, double, triple winds?
ORIGINAL: Corporeal
ORIGINAL: adam-69
double more rpm, triple more torque
so you're saying a 19x3 arm has more torque than a 19x2.. is that right?
Three strands of wire will generally have more cross sectional area than two, even if they're slightly smaller in dia. so theoretically you can flow more current through a triple vs. a double...
A triple will have more Copper per turn than a double...so it also changes or it can change the Copper to Iron (of the stack ) ratio.
All of that needs to be balanced by the strength of the magnets...the timing, etc. etc.
It's hard to say really if a triple will work better than a double or single, because there are a lot of variables involved.
