RCU Forums - View Single Post - 3W ENGINE PROBLEM
Old 03-15-2008 | 05:26 AM
pe reivers
Default RE: 3W ENGINE PROBLEM
I wonder if anyone ever tried a pitot tube construction for carb reference pressure?
From information I have gathered so far, if the connecting line to the carb membrane plate is too long, it may set up pulsating vibrations and thus upset good carb function as well. In case of a long line, the reference line should be provided with some form of choke nearest to the carb connection. (i.e. piece of foam stuffed in)
