RE: ZING!!!!!!.......threadlock needed!
To lock screws into plastic simply apply a little CA in the hole where the screw goes. Run the screw in and out of the hole first to create threads. Loctite is not compatible with plastic (at least regular blue loctite isn't), so you can't use it to threadlock screws in plastic parts. HTH
