RE: starter shaft
Try to heat it up then use a different size hex or find a small screwdriver you can wedge in there and get some grip. Sometimes the hex wrench itself gets a bit worn and will cause the screw to strip. Try a new hex wrench of the correct size and you might be able to get enough grip on it after you heat it up. You can heat it up with the tip of a soldering gun.
