RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
starter shaft
Old 03-15-2008 | 09:51 AM
Default starter shaft
On my starter shaft there is a little set screw that keeps the shaft from rotating. when i tighted it i accidently stripped it and now i cant get it out. ANY suggestions will be appreciated.
Old 03-15-2008 | 10:34 AM
Default RE: starter shaft
Try to heat it up then use a different size hex or find a small screwdriver you can wedge in there and get some grip. Sometimes the hex wrench itself gets a bit worn and will cause the screw to strip. Try a new hex wrench of the correct size and you might be able to get enough grip on it after you heat it up. You can heat it up with the tip of a soldering gun.
Old 03-15-2008 | 11:09 AM
when i strip off the ends of my small hex wrenches, i just dremmel off a mm or 2 and there good to go again ;-) albeit a mm or 2 shorter.
Old 03-15-2008 | 11:31 PM
ORIGINAL: ginnz
That works for a rounded wrench but how does that fix a stripped set screw???
Old 03-16-2008 | 10:44 AM
evan-RCU's Avatar
Most times the set screw is partially stripped and the hex driver is partially stripped and between the two it slips. Try what Busa and Ginnz say, it sometimes works. Heat helps if there's locktite, if nothing works it's dremel time...
Old 03-16-2008 | 07:05 PM
You can try a dab of JB weld on the end of a hex wrench. Clean everything real good with alcohol first, and let it set for 24hrs.
Old 03-17-2008 | 03:13 PM
rcjon, That's a good idea!
