Prop Stud
Take out the spark plug, put as much nylon rope into the cylinder as you can get in..Put two nuts on the stud, tighten against each other as tight as you can..Heat the hub slightly to soften the Loctite on the stud, unscrew the stud with a wrench on the nut closest to the engine...Reverse the procedure to replace the stud...
