RCU Forums - View Single Post - post some pictures of your pattern plane!!
Old 03-16-2008 | 09:35 PM
  #487
riot3d
Default RE: post some pictures of your pattern plane!!
Maidened my X-treme ProLine this afternoon, only had time for two flights. First impression, not bad at all. The plane felt a bit tail heavy, cg very similar to my Akiba built ProLine. Unfortunately, it's over weight - 5.05 kg, have to find a way to lighten it. Mine is the first 5 prototype imported by BVM, and I think it is the heaviest.
I started off with about 1/2 degree pos wing incidence, but had been gradually reducing it. Up/ down line very solid, slight pull to the belly on left rudder, and very slight pull to the canopy on right rudder. Hopefully, I will have a chance to fly again in the next few days.
YS 170DZ
APC 17x12 W, will switch to 17.25x10/ 11 after engine has more flight time
Futaba 14MZ with 5114 rx
Futaba digital servos
K&S 600cc tank
4.8v 1,500 mAh ni-cd
Adrian
ID:	905343   Click image for larger version
ID:	905344   Click image for larger version
ID:	905345   Click image for larger version
ID:	905346   Click image for larger version
