1. Ive had my mgt for almost a year and haven't bent or broken and turn buckles. Lunsford turnbuckles are probably the best if you feel that you need to replace them.
http://www3.towerhobbies.com/cgi-bin...&I=LXGDZ7&P=ML
2.
http://www3.towerhobbies.com/cgi-bin...?&I=LXFVB7&P=7 This is for the updated instructions if the instructions they give you are wrong.
http://www.monstergt.com/articles/transmission_foc.php
3. The stock A arms and towers are plenty strong.
4.
http://www.neweramodels.com/item.cgi...=&part_id=2877 http://www.neweramodels.com/item.cgi...=&part_id=2062 You need that shock tower for the wing kit.
5. Can't really say whats the best..I don't use one except for the stock one.
6. I don't think there are any bad fuel lines to buy?
http://www3.towerhobbies.com/cgi-bin...&I=LXK129&P=ML
7. I would choose at least a 20% fuel. What ever you choose stick with it. I personally use oddonels 20%
http://www3.towerhobbies.com/cgi-bin...?&I=LXMGE5&P=7
8. Again I don't see any durability issues with the stock wheel tire combo. They are just heavy.
9. I suggest you just get the FOC kit 8 Aluminum Shock caps
http://www3.towerhobbies.com/cgi-bin...?&I=LXGHA3&P=7 and 4 Hard springs
http://www3.towerhobbies.com/cgi-bin...?&I=LXFUC6&P=M One in each corner. And the rechargeable Receiver pack.
http://www3.towerhobbies.com/cgi-bin...?&I=LXLDK2&P=7 After that it will be fine for A while. This has been my set up for about a year now. No issues.
