ORIGINAL: soloboss
So yer like way smarter now, huh? So how's it feel?
Someone sells an alloy center piece and you can use a CF rod for the flybar. That sounds like the hot setup.
Who remembers where the alloy center thingy is located?
soloboss
DO NOT PURCHASE THE ALUMINUM FLYBAR HUB without reading this!
I experimented with these to go along with the LED flybar paddles and I must say that the hubs are WEAK! In order to use the Xtreme Aluminum hub, you must also use the Xtreme flybar rods. The rods are made of steel, while the hub is aluminum. In a crash, the hub cracks quite easiy! I broke 3 of these hubs before I went back to stock.
The only way I could see using the Xtreme flybar hub is with a CF flybar rod, which I haven't had a chance to try yet.
