RCU Forums - View Single Post - Hyper/Picco .28 Massive Issues
Old 03-19-2008 | 10:14 AM
  #83
vnmsgt's Avatar
vnmsgt
Default RE: [Awaiting Approval]
ORIGINAL: qaiz
Ive just checked ALL the conncections. Still no go.!?
Ive tried using my stick packs and 4 differient gel cells. Still nothing.
My connections are fine, I think..
But the electricity is not going through.
I mean before when I used to press down, there used to be a quick spark and then the motors would fire ( Spark was where the Plate on that thing you press down meets those other two terminals ) and now theres nothing []
Anyone know what could be the cause. Please dont tell me my starter box's gone bust [:@]
And the motors werent that hot, only the wires were a bit and thats it.
Thanks..
Where you said you had the spark and that plate that meets the terminals is where I was talking about. You should have a tab on each side (one for each terminal) check that they are not bent down or melted in the plastic. They are probably not touching.
Just saw the pic. The one on the left side is melted and the tabs are bent down like I said. Disconnect the battery and bend them back up and see. There is also a piece of plastic on top of the tab you have to scrape off.
