RE: 46Rossi 46 problem
Hi!
0-5% nitro, Rossi 5-6 glowplug and 11x5 APC prop!
Then start the engine and set the high speed mixture to slightly rich setting (reduce max rpm 300-500 rpm) and check the full speed .Then throttle down and set the low speed needle for a good, slow idle. The engine should then respond instantly to full power.
