RE: Conversion Engines - Descriptive Lit.
Poly board? Cutting board? I found that rotating the carb position 90degrees with a temporary dowell connecting the vac ports, two undrilled
pads appear to drill and tap, this positions the mixture screws aft and 45 degrees up, I'll just use a thicker gasket.
