RCU Forums - View Single Post - vibration
Thread: vibration
Old 03-19-2008 | 05:14 PM
pe reivers
Default RE: vibration
same things as a glow engine, except, that the gas engines vibrate less than glow engines because they have a better controlled ignition and lower compression ratio. Gas engines also tend to run at lower rpm.
Balance props well, take care of proper prop track, use iso-mounts if need be.
