vibration
Old 03-23-2008 | 10:59 AM
buck1856's Avatar
My Feedback: (49)
Default RE: vibration
1.5 inch thick large dowels,then a 1 inch thick piece of rubber.Run bolts all the way through evrything then use Locknuts with the plastic in them.
Old 03-23-2008 | 03:34 PM
BillHarris's Avatar
ORIGINAL: tande
As far as I know, the Hyde mounts are made only for the "YS" type of 4-stroke glo engines. Are the now available for gas engines?
--Bill
Yes, they are, Bill---He will custom/build for most any application---I use them on my 100cc twin & down---No more cracked cowlings-canopies-etc.---I'm a "Happy/Camper"---
I'll check with Hyde, then.
--Bill
Old 03-25-2008 | 03:51 AM
BaldEagel's Avatar
ORIGINAL: BillHarris
It may be do-able. I have a Brison 4.8 Twin that I'd like to use it with, and as fate would have it, the spacing between two of the mounting bolts is 78mm ( the same as on the MVVS bracket). Are the MVVS mounts available thru a USA dealer, or should I ping Pe R?
--Bill
Bill
The Evolution engines which are available in the US are a badged MVVS, I would think therefore that you should be able to get the mounts from an Evolution stockist.
Mike
