RE: Hangar 9 B-25 ARF: Building and Modifications
After reading the post about the nacelle templates I couldn't recall the left and the right, only GP and EP. I just looked at the templates and realize Hanger 9 made a mistake. I have two GP-L templates and two EP-R templates. Is this going to cause any problems with the model. I have put the two EVO 46's in already and mounted the cowlings with the plastic radial engines in. There doesn't seem to be any real difference in the locations of the motors to the cowlings or dummy engines. Also, I used the pre-drilled holes in the motor mount that ends up putting the engines 1/4" ahead of the reccomended distance of 4 3/16". Has anyone also kept the motors ahead like this. Thanks for the info Tevans 55. How far is the thrust washer from the firewall on the OS's? Also, on the cowling screws, they do not hit wood like the instructions say if you put them where reccomended.
