ORIGINAL: pe reivers
same things as a glow engine, except, that the gas engines vibrate less than glow engines because they have a better controlled ignition and lower compression ratio. Gas engines also tend to run at lower rpm.
Balance props well, take care of proper prop track, use iso-mounts if need be.
Could you show me an example of an iso mount and where to get 'em?
