RCU Forums - View Single Post - Do I miss a needle here?
Old 03-20-2008 | 10:01 AM
carlosponti's Avatar
carlosponti
Default RE: Do I miss a needle here?
if i am seeing correctly you have a high speed needle adjustment its the one with the spring. it has an 'h' underneath it. the one with the 'L' under it i can not tell if its adjustable. someone can tell you where you start your settings. I have set them but i guessed at the starting point.
